Geometry type of view in Oracle Spatial
I've understood that Bentley Map reads the spatial index to determin the geometry type ie. point, line og polygon of a table in oracle. Now what's going on with views? Belowe is two screen shots. One of the view afl_broend which is a view on the table gis_drain_wells. afl_broend incorrectly is shown as a area feature (or collection?) and gis_drain_wells is correctly shown as a point feature. Can I force afl_broend to be interpreted as a point feature with the point symblogy options that gives ie. point, cell, text?
  • Jakob,
    A few questions.
    • Do both views refer to the same base table?
    • Is each view defined in such a way as to guarantee that all rows returned contain the same geometry type?
    • For the AFL_BROEND feature class, what is the layer_gtype parameter defined for the index of the referenced table?
    • What version and edition of Bentley Map are you using?
    • Do you see similar behavior when you use the "Register Feature" process in the Bentley Geospatial Administrator application to create a graphical source?
    Jeff Bielefeld [Bentley]
  • Jeff,
    I was communication unclear:
    - afl_broend is a view of gis_drain_wells (create view afl_broend as select * from gis_drain_wells).
    - Yes, as the view is basicly just a renaming of the table - no where clause or joins. Other than the definition above and the index' layer_gtype there is no garantee.
    - Yes, layer_gtype is set to MULTIPOINT for the spatial index of gis_drain_wells - id actually expect it to be just "point". Not sure why its multipoint and not point.
    - I use Bentley Map SS2 (standalone) v08.11.07.434
    - "Register Feature Wizard" only shows me tables - no views - I'd expect it to give me all entries from mdsys.user_sdo_geom_metadata!? Views are registered in user_sdo_geom_metadata.
    Regards. Jakob
  • Hi Jakob,
    AFAIK, in addition to inserting entries into user_sdo_geom_metadata, you must also define a primary key for your views so they would appear in the list of features to be registered. Have you done anything similar to the following?
    alter view AFL_BROEND add primary key (YOUR_PK_COLUMN) disable;
    Regards, Matti
