Hi
Here is another problem with PolygonCollections in 3D geospatial data:
Importing data in a 2D designfile looks this way:
But importing the same Gml file, which has 3d coordinates the building looks like this:
Topographical and techical mapping in Denmark are in 3d always.
What could be wished was a posibillity to have Bentley map, when in topview, to behave like the designfile was 2D for polygon filling, for display order and for properties generated by BMap like Geometry_area, perimeter and lenght.
Erik Wirring
GEOspatial SIG - BentleyUserDk
Hi Erik,
This is definitely an issue and if you can provide me the GML dataset (maybe already exist in a previous post?) that will be helpful to reproduce and fix the problem.
Thank you and Best Regards,
