I am trying to import CSV file. I made the VRT file, but when I try to import it with the Map Interoperability I have a following error:
Error opening data source: XXXXXXXXXXXXXXXX.vrt, error message: Failed to open datasource `XXXXX.csv'.
What can I do and how and where to fix the problem?
Thanks!
Keti
Keti,
Can you post your CSV and VRT file? so we can evaluate the problem.
Jun
Keti says: There is no problem when working with Windows XP.
With Windows 7, the CSV, VRT and DGN files have to be in the same directory. If the DGN is in a different directory than the CSV and VRT, the full path to the CSV file has to be included in the VRT file.
