Hi
I have a college that needs to create MapInfo files from an old GeoGraphic project.
I have not tried this before so if anybody can help me I would be glad.
We can easely review all attributes from the Access database when keying Review, but when we try to create Tab files through the GIS file export we gets no atttributes.
Erik Wirring
GEO SIG -- BentleyUser Dk
LE34
Danmark
We need to import legacy project into Map via Geospatial Administrator first then export to MapInfo .TAB files. For more details, please refer to help file: docs.bentley.com/.../GeospatialAdminhelp5.html
If it is what you already done, I cannot explain why it does not work properly. I just tried with mytown project and attributes are exported in a MapInfo tab file properly.
I know it is obvious here, but since no one has gives any inputs, I decide to post basic solution here. Obviously, if you can provide a part of the GG project maybe I will be able to reproduce the issue on my side if it still persisted.
Best Regards,
