I have problem with Bentley Map Mobile in Sony Xperia Tablet Z, Android 4.3In demo map EastCity and in my map I can't see all lines, only can see some points from those lines and can select the line. I try to clean fully my device and install app, result was the same.
What I can try to do?
Unfortunately I can't to downgrade to previous version of Android.
What version of Bentley Map Mobile are you using?
Make sure the Features for those layers are turned on in the View Filters settings. Other than that, we will have to test the specific OS on that tablet.
Ver. 03.00.01.12
All layers is on.
I try in another tablet with Android 4.3 (Samsung Galaxy Note 2014) - all work fine!
I solved the problem - changing weight of all lines no more than 1
But question - is it problem with BM Mobile or with Sony Tablet Z?)
Answer Verified By: Dan Weston
The same problem is with Asus MeMO Pad FHD 10 LTE
ME302KL, Android 4.2.2
Maybe I need to install something additional?
