Initial Value
I am using the Bentley ArcGIS Connector to create new DGN files from an Arc SDE DB and the problem I am having is setting the initial value for a property of a feature.
When I extract the spatial data I have a filter, as the SDE contains (or will once I get this working) lots of projects, set to only return data with a specific project id. This works great but when a new feature is placed the project id is blank, I would like it to automatically populate with the current Project id.
There is a table in the DB that is populated with project details, including the project id, before the spatial data is extracted by Project Wise.
So my question is: How do I connect the two tables? What do I need to do to populate the Project id text box of new feature when it is placed?
Any help would be greatly appreciated.
-Patricia
Parents Reply Children
