So currently I have a .DGN with many shapes/polygons each one has an array of information stored in it that is accessible through the Element information button or Item Browser, but when I load Bently Map and export to .SHP files all of the information is dropped.
Does anyone know how to remedy this?
Hello There
Can you please share the dgn file? You can mail the file to mayur.pandya@Bentley.com.
What version of Bentley Map are you using to export to .shp format?
Mayur
Unknown said:So currently I have a .DGN with many shapes/polygons each one has an array of information stored in it that is accessible through the Element information button or Item Browser,
How the data was created and where the attributes (business items) come from? Were they created using MicroStation, Bentley Map or some other product?
Unknown said:but when I load Bently Map and export to .SHP files all of the information is dropped.
SHP export in Bentley Map works with Bentley features defined in XFM project. In other words, data created in MicroStation e.g. by SHP import into DGN file are different animals (from technology point of view) than data created using Bentley Map.
If you want to export file content to SHP file, you should us Bentley Map from the beginning.
Jan
