Map Export to Shapefile - Missing Attributes
All,
I have a dataset in Geopak Map that looks good and I can analyze the properties and the associated values of each point. When I export to a shapefile and then reference that shapefile into a DGN, I will go to the same point, look at the element information and see that all the properties are there, but very few of them have values. Any idea why it wouldn't be showing all of the values that were stored in Map?
Parents Reply Children
