Hi
I just can't make this rather simple setup working.
I have two comboxes: One with a Main-categori list residing in a domainlist which is refrenced, and a second which have to have a sub-categori list depending on what is selected in the main-categori. These domain list are referenced too, I have set up a property watcher on the main-categori.
On the sub-categori domainlists I used referenced criterias --and I know they work because the PBS color works as it should. But I get all the time the last domainlist in the sub-categori combobox which has no criteria ! It looks like the criterias do to work here. I am pretty sure that my failure is somewhere in this part of the meta datafile:
I have looked and looked in the address feature in the geo_example.xml but I simply can not find out what I am doing wrong.
Maybe somebody are able to pinpoint where the problem is located. I have been wondering why the GSA create double useCrietrias, but it seems not to make any different if I delete one or another os them.
Hope somebody can help ( I have attached a cut down to minimum metadata project -you might need to change the Workspace Root Directory)
Erik Wirring
Le34
Erik,
I attached a custom example inspired by your schema and Address feature from geo_example. In the Define Property Watchers tab, select an item and edit the Synch Item Watcher Details section at the bottom. Also, you will have to add a synch Item for each ComboBox watched.
More, it seems you will need to add the feature name in the COMPARE criteria expression to be more efficient with the watchers. For instance, you will have to set the “KatOver Andet” named criteria to COMPARE("[StedfæstelseFlade:Kat1Over]","Andet","|")
Answer Verified By: wirring
