Geospatial Administrator connect to SQL Server View
Hi All,
I am wondering if it is possible to connect to a MS SQL Server view as a graphical source. I have created the view with an unique clustered index but when attempting to retrieve feature data from it via Graphical Sources> SQL Server Spatial Connection> Named Connection (My Connection)> Register features the view is not listed under the 'Please select features to register.' window. If I select view report then the view is listed with the note 'No object identifying property was discovered', which I assume refers to a lack of primary key.
Can anyone shed some light on this for me?
Thanks.
Parents Reply Children
