I am working with a process where I have Bentley Map Design files, and I want to export the XFM feature information to another format like MapInfo TAB or other GIS format. I have tested this to work with the File | Export | GIS Data Types | TAB directory through the GUI.
The issue is that the process needs to be automated, so that it can be run from the command line, or as a step in a script, or in batch for a set of Design files, preferably without ever opening the Bentley Map GUI. Can this be done?
I have read about MDL commands, but the exports do not seem to include these GIS Data Types. also msbatch commands have some conversion functionality, but do not seem to include other formats.
TIA,
Regan
Hi Regan,
it's possible in my opinion, but as usually there are some tiny details which can make the solution more complex.
The most simple way is to drive the export process by key-ins. Search Bentley Map documentation for gdi export key-in, you can use it e.g. in a batch process job, but Bentley Map GUI will be active in this case. To start Bentley Map in a background, may be OLE Automation can be used.
If key-in will be not enough, you can use GeoDataInterchangeAPI accessible from NET addin. By default the add-in is started from Bentley Map GUI, but there is a way how to create addin as INITAPPS.
With regards,
Jan
