Hi all,
I have published data from Bentley mobile publisher and I am going to use it as my map data. How could I open the file using Bentley map mobile? I can only open the example file as it is already loaded.
Jun
Hi Jun,
I think you should copy your published data in mobile format into the same folder when example imodel is placed and the data should be available for the opening automatically.
Jan
Jun,
After loading your data onto your device, you must ensure that you have successfully signed into the Bentley Map Mobile app to see your data. Please see the "Bentley Map Mobile - FAQ" for other potentially useful information.
Jeff Bielefeld [Bentley]
