I have imported gml data into the attached file. When I try to create an I-model...
In Bentley Map Enterprise 08.11.09.107 I get the error...
Error creating file:z:\.......\Lgate_076_testdata.i.dgn
The attached is a very small sample of a much larger data set. Can someone test this for me please?
Thanks a lot
Mike
I do not reproduce the error your reported here with attached file. I used default Publish I-model dialog options. Which option are you enabled ?
Do you have right to create(write) file in the folder path which report the error?
Mike,
Using the provided design file and following products...
...was able to successfully publish i.dgn and Bentley Map Mobile .imodel files, each of which are provided in the attached archive.
Jeff Bielefeld [Bentley]
Hi Sebastien,Thanks for testing. Sorry my information was a bit lacking.
The attached xml is the settings file I used for I-model export. ( single package, remove intermediate files). These settings cause the error for me.
I see now the default settings finishes without error but the attributes are missing. Why is that?
Thanks Jeff
I checked your results and the attributes are missing also.
I see the following attributes in the published LGate_076_testdata.i.dgn file. Which product and tool are you checking attributes with?
