Problem with imodel in Map publisher on BM.entreprise
I m working on a DGN file that contains a lot of text elements with geographical coordinates ...
when I publish it with map publisher (latest version) , the result file - Imodel -  is not satisfactory on my tablet
Research is Innactive. (No result). and no filter on the output file *. Imodel (see photo)
what is the procedure to get a good result with Mobile map publisher?
my little project is here >> DGN
Thank you for support.
