I am having problems, when i wanted to visualize Vector Data on OpenCitiesPlanner, I cannot see anything, I uploaded from two ways:
1- DATA MANAGER - FEATURE - VECTOR DATA SHP and later Create Mapa Dataset - Feature
2- Terrain Texture, I dropped the SHP, SHX,DBF and nothing
Which is the correct way to upload and visualize the Shapefiles on the MESH or DSM??
Hi Juan,
Both processes are correct.
You either create a Map dataset using as a Source the shapefile you have uploaded or by drag&dropping the .zip on the Terrain Texture.
When you do that be sure that there is no other issue with the file itself, maybe it is empty. Please check on the GIS software you use that your .zip file has content.
If this is not the case here, please send us a Support Ticket via our Help section and we will handle that properly, as it can be a bug that needs our attention.
Thank you.
