error no display properties of feature when place any element in bentley map
Hi all
I have an error and I can't fix it, Please help me to solve this issue.
It happened with all dgn files be extracted from 1 sde. When I use place tool in Command manager to place some new elements, I do not see all properties of the feature for editting them. You can have a look at below image.
Ngoc
  • Hello Ngoc,
    Is there customization in the placement method or is it a standard one? Could it be that the feature called 'Diemcosolanhhai' was modified, for example a new property 'Toadoy' was added? In this case you have to recreate the feature placement tools built in Bentley Geospatial Administrator by adding placement data. So you could try to Right-click the Diemcosolanhhai feature node and select Insert > Linear Placement Metadata...
    Then export the workspace and try to place the feature again.
    Carlos
