[GWP] Pentable hook macros
Why pentables with macro doesn't work in GWP? If I open GWP engine it correctly shows printout but not when publishing using Automated iDPR. Is there some security or timeout settings which prevent it to run? Pentable is loaded as other sections execute only the section with macro is not. We need pentable macro to map RGB white to RGB black on printout.
