Hi all,
i'm pubblishing raster image (hmr format).
Image background color is white but i need to render them with the trasparency background. There is a GWP feature, suitable from WMS, that can help me?
In the example below i would like substitute white pixel with a "trasparecy color".
Fabio
Hi Fabio,
The HMR file format doesn`t support pixel type with transparency (i.e. : alpha channel). If your raster is attached in a DGN file and your are publishing the DGN file, you can try setting white has the transparent color for your HMR file attached in the DGN.
The setting of a transparent color can be done with the controls at the bottom of the Raster Manager dialog box.
Mathieu
It is possible to apply transparency on raster images for a specific color by creating a pss file (PictureScript Scene).
Here is an example of pss file that can help you:
;References to images AerialImg1 = imagefile("Aerial1.iTIFF") AerialImg2 = imagefile("Aerial2.iTIFF") AerialImg3 = imagefile("Aerial3.iTIFF") ;Apply transparency (opacity 0) on the color #0 opacity1 = alphapalette(0, 0) AerialImg1x = translucentimage(AerialImg1, opacity1) AerialImg2x = translucentimage(AerialImg2, opacity1) AerialImg3x = translucentimage(AerialImg3, opacity1) ;Combine the images into a single mosaic result = mosaic(AerialImg1x, AerialImg2x, AerialImg3x) ;Show the final result PAGE(result)
Save this code in a .pss file in the same directory as your hmr images then add a graphical source that point to this file.
HTH
Sylvain
