Hi
If I have many cell objects that looks like this (very close up zoom level) and I have approximatly 700 dgn files convering a big extent. The cell is made up by many line string objects and one circle object and one point.
When i convert the dgn files using automated iDPR in BGWP administraton program the cell ending up looking like this:
If I increase precision to maximum 100 and convert a smaller extent area (less dgn files, 25 files) I can get the cell to look like this:
Which is better than the above but still not like it look in the original. And preferable I would like to convert many files at a time not have to set up 100 of diffrent automated iDPR jobs
So what would be the best way to make the cell look good via wms created by BGWP ? Its not necessary to view all the different lines within the circle, but its a must to see that its a triangle within a circle.
I had another look at the cell and I strongly suspect 'the huge grey circle' is caused by the point element in the cell. I changed the color for better viewing
I copied and scaled the cell just beside one of the cells, I run the conversion and the result is this one (the red line is just there for location purposes, don't mind with that). On the left the circle is covering in fact the entire cell, on the right the copied/scaled cell is partly visible, and you can see the same circle with the same size, it's the point...
I believe the solution could be to get rid of this point, ideally achieve this during iDPR conversion but the fact the point is part of the cell doesn't make things easy.
