I have point-cell feature in Oracle Spatial table. When posting the feature into DGN in Bentley Map, it's correctly created as partially filled cells. But if converted to idpr format, the fill is lost. But the fill is mandatory for this feature, because without the fill the cell cannot be read properly (displayed like plenty of lines).
What is a recommended solution?
With regards,
Jan
Hi Jan,
I may have to test this but before could you please verify if the seed file specified during the iDPR conversion has the Fill attribute enabled. Open the seed file in MicroStation to check this.
Answer Verified By: Jan Šlegr
