I need to map a project for Las Vegas. They require use of their Low Distortion Projection. I have all the parameters but can't figure out how to create a new system. I found some things for previous versions involving copy and paste of the seed.dty file but can't seem to find a way to create an editable system in Connect version
Hi Jon,
Bentley Map is required for creation / editing of a custom coordinate system definition. Please have a look at:
https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/6548/--defining-a-custom-coordinate-system
Are you using a Geospatial Server product or ProjectWise with the custom coordinate system? If so, please clarify which products.
If the question relates specifically to MicroStation / Bentley Map desktop products, we can relocate the post to the appropriate forum.
