Geo Web Publisher is no longer avaliable, what product can i replace it ? I am using BentleyMap to publish data via oracle DB and an idpr basemap. GWP for web user.
Hello Chi,
Thanks for your submission. You are correct, we are not expecting any further releases of Geo Web Publisher at this time.
Please log a service request via the portal and we will discuss your workflow needs and a way forward therein.
I do not have sufficient privileges for accessing the service request manager...
There is no real alternative for DGN publishing without GeoWebPublisher. Geo web publisher is using Bentley Map as an caching engine so it was possible to have one-to-one publishing(WSIWYG) and get the same result as viewing DGNs in Microstation. GWP is great for at least WMS 1.1.1 publishing except the stupid bug which never was fixed even that customers are still paying SELECT for GWP and no replacement product exists. With such slow support from Bentley regarding publisher I am afraid it will take years to have usable replacement.
Other solution would be to use Opendesignalliance SDK to do publishing like this cloud solution - http://cloud.opendesign.com/#/
Any updates about this topic? OpenCities planner is not a replacement for GWP and any resource hungry 3D publishing is not replacement for 2D maps.
Recently logged another issue regarding GWP and received a note from Bentley that "GeoWeb Publisher is a retired product, functionality now resides in AssetWise ALIM."So does the AssetWise ALIM now contain GWP? Does it allow DGN publishing as WMS?
