I have installed Bentley Geo Web Publisher server component and licenced it (the licence manager says licence is activated), but every time I try to view examples, the service stops and logfile says it stops because of licence expiration. Also, when trying to view examples, I get the following error message: ERROR: Unable to load the map definition file: 2fe1933d-79b3-47b7-8f33-b789fdf432fa 'text' is an unexpected token. The expected token is '"' or '''. Line 1, position 63. The server I use is Windows Server 2012 R2 Standard (64-bit), IIS version is 8.5.9600.16384. I have also Microsoft ODBC driver 11 for SQL server and Microsoft SQL server 2014.
Thank you. I have the necessary license components and I have gone through the verifivation processes (were already before the post), and everything seems to be ok with the licences, but for some reason the mentioned problems come up.
Are the Licenses activated for all user at the Server? Normally the GWP servises runs as the System account. If you have activated for Current User, then please see this page https://communities.bentley.com/products/licensing/f/licensing-and-activation-forum/148622/activation-for-multiple-users-on-one-machine
Check that in windows regional settings there is decimal separator as point and not comma.
