We are running ArcGIS 10.6 and I have been tasked with finding a way to connect ProjectWise 10.00.03.271. Does a "ProjectWise for ArcGIS Connector" even exist for the Connect family of software? Has it been renamed to something else? Any help in pointing me in the right direction would be appreciated.
Thank you
Phillip Hess
Federal Highway Administration
Hi Phillip, Apologies if we've already discussed this, and apologies for the delay if not. The ArcGIS Connector is not available for Update 3 and likely will not be available beyond the initial PW CONNECT Edition release 10.00.00.13 in its current form. The ability to extract/modify/post SDE/Enterprise Geodatabase features via a ProjectWise session may persist in some form thereafter. In the case of your request above however, I expect that you intend to seek the iDesktop for ArcGIS, which is not part of the ArcGIS Connector, instead it is available via ProjectWise Geospatial Management's iDesktop for ArcMap
iDesktop for ArcMap from the current release (10.00.3.322) supports ArcMap 10.6 and 10.7 presently.
thanks,
Nels
