GWP site has been running fine until a few days ago when it started showing this error message '' 'text' is an unexpected token. The expected token is '"' or '''. Line 1, position 57 ". I tried rebooting the server but the problem does not seem to go away. Any idea how i can resolve this issue?
Thanks.
What does the Error logs tell? Please use Log Viewer from GWP.
I have seen this error if licences are missing or not enabled for all users in the server. Please see this Wiki, https://communities.bentley.com/products/geospatial/server/w/geospatial_server__wiki/11325/gwp9905-geo-web-publisher-license-components
and also this page https://communities.bentley.com/products/licensing/f/licensing-and-activation-forum/148622/activation-for-multiple-users-on-one-machine
Bakang, please also specify the build of Geo Web Publisher (or Geo Web Publisher for Communications) in use, and the server OS details.I would suggest attempting to view the map from the delivered Mapviewer example, on the server itself. Do let us know if the message presents itself there likewise.
The error just disappeared and the Mapviewer works fine again. Not sure what resolved the issue or what the cause was.
Thank you. Much appreciated.
