dimension lines not showing in the Publisher
We're using Geo Web Map V8i and I have now noticed another apparent problem(s) with the idpr conversion. This seems to involve dimensions and groups. I don't remember these being a problem with the V8 XM version of the viewer
I have dimensions for our water facilities that were created using one of the dimensioning tools in MicroStation. At these locations the number (dimension value) appears on the viewer screen - but the terminators and the leader lines do not appear. However I just found one location with two dimensions (to different mains in the same street); one of these only displays the number value (no leaders and terminators) and the other only displays the leaders and terminators (no number).
I have observed a problem with text and leader line created by the place note command; these elements are created as a group (or cell). The leader line is visible, but the text is not displayed. And now I've found a location with the text being visible and the leader not being displayed.
This display problem in the viewer is disquieting.
Anyone else notice the problem(s)? I guess I should report this via a service ticket.
