Hi everyone,
I am trying to install GeoWebPublisher v8i on a PC with a Windows 7 OS on it, but just can't make it work properly.
During installation everything is working fine but my problem is that right after installation, when I want to enter the Administration program or if I want to take a look at the example page provided, nothing is working.
First problem: After entering the Administration program, after trying to log in, it throws me a 404 :(
Second: In IIS 7, I see no applications in the list like webservicesGWP etc. under the default web site tab opposed to the case with winXP where everything works just fine for me.
I would appreciate any help concerning these matters!
Hi. It is possible that you have trouble installing the server portion of GeoWebPublisher on Windows 7 as that is a "client" OS and thus isn't a supported configuration. Please make sure the server portion of GeoWebPublisher is installed on a server operating system, like Windows 2008 Server for example. The supported operating systems are listed in the readme file.
The client portion should run without problems on Windows 7 if you are using the latest release. Again, please refer to the readme file for the supported client operating systems.
Hope this helps,
Martin
Hi Martin!
Thanks for replying.
In the meanwhile we figured it out, if we install GWP v8i on Windows 7 "as an administrator" it installs smoothly and nothing is going wrong.
cheers
Tamas
