MapViewer: How to use Static Top Overlay API?
I tried to use Static Overlay Api to create custom copyright text statically displayed on all map. To do this I tried to call both STO creation :
  • CreateDprRenditionStaticTopOverlay("Copyright", 0, 0, 9, 10, 10, 10, 10)
  • CreateEditableStaticTopOverlay(9,10,10,10,10)
But both raised an exception: COM exception, HRESULT E_FAIL
I don't know what is the problem since there is no any example in API reference about how to use them.
Could anyone describe STO usage in more  detail than API reference?
  • Hi. The function CreateDprRenditionStaticTopOverlay needs a DPR rendition as its first parameter. You can specify a local path or a URL to a DPR file/rendition. This is probably why it fails.
    If you want to display static text, I think you should instead use CreateEditableStaticTopOverlay . Looking at the documentation, that function requires 7 parameters like this:
    CreateEditableStaticTopOverlay (isViewRotationDependent, predefinedScreenPosition, pixelWidth, pixelHeight, originOffsetX, originOffsetY, requestedOverlayIdx)
    An example call would then be:
    CreateEditableStaticTopOverlay(FALSE, 9, 100, 12, 10, 10, &OverlayIdx);
    OverlayIdx is the index of the overlay you just created, as a return value. You will then use that index in the element creation calls (AddStaticTopOverlayTextElement, etc).
    hope this helps,
      Martin
  • Hi,
    Here is an javascript example to display text as static top overlay in the Map Viewer:
    var overlayId = document.MapViewerControl.CreateEditableStaticTopOverlay(5, 300, 30, 0, 0);var rendId = document.MapViewerControl.AddStaticTopOverlayTextElement(overlayId, document.MapViewerControl.VBArrayFromJavaScriptArray(new Array(0,0)), "Copyright  2011", "Aerial", 30, 0x0000ff, 1.0, 2);
    Sylvain
  • By the way, let me apologize for posting the wrong function signature. I think Sylvain has it right here. I looked it up in the wrong documementation...
       Martin
  • var overlayId = document.MapViewerControl.CreateEditableStaticTopOverlay(5, 300, 30, 0, 0);
    This is exactly what I tried. It always throws an exception: H_RESULT E_FAIL. I tried it with many different parameters to test but always got an exception.
  • Did you load a map definition prior to use the top overlay methods?  If a map is not loaded, I also get an error.
    Sylvain
