Geo Server with PW SS4
Very much interested in moving foward with ProjectWise Integration Sever and clients 08.11.11.111 (SS4) is Geospatial Manager and client 08.11.09.06 compatable?
thanks
  • Hello Neil, the 08.11.09.06 version is not certified to run with PW V8i SS4 08.11.11.111, you will need to wait a bit longer. Although I do not know at the moment the official release date of the PW Geospatial Management V8i SS4 and the GeoSpatial Server V8i SS4 we shouldn’t be too far away from it.
    Carlos
  • Carlos,
    It is my understanding that ProjectWise Connector for ArcGIS V8i SS3 *is* compatible with ProjectWise Integration Server SS4 (08.11.11.111). (This is according to Eddie Anderson's tweet about it - twitter.com.
    ArcGIS V8i SS3 (08.11.09.12) has dependency requirements of ProjectWise Geospatial Management SS3 (08.11.09.18).
    Therefore, shouldn't ProjectWise Geospatial Management SS3 (08.11.09.18) be compatible with ProjectWise Integration Server SS4 (08.11.11.11)?
    I know PW GM SS3 08.11.09.18 is slightly different than the version Neil is talking about, but if he upgraded from 08.11.09.06 to 08.11.09.18, would it be compatible?
    Les
  • One prerequisite of the Connector is ProjectWise Geospatial Management. Since ProjectWise Geospatial Management Ss4 is not yet released, ProjectWise Connector for ArcGIS Ss3 cannot be deployed over ProjectWise Ss4 for now.
    As soon as ProjectWise Geospatial Management Ss4 will be available, then you could use (if you can`t wait for the Connector Ss4):
    ProjectWise V8i (SELECTseries 4)
    ProjectWise Geospatial Management V8i (SELECTseries 4)
    ProjectWise Connector for ArcGIS V8i (SELECTseries 3) (or Ss4 if you can wait…)
    Seb
    Sebastien Cote
  • Thanks for the clarification Sebastien. Somebody should tell Eddie Anderson, Global Practice Leader for ProjectWise, that his tweet that says, "The ProjectWise Connector for ArcGIS V8i SELECT Series 3 will run with ProjectWise V8i SELECTSeries 4" is incorrect.
  • Since it is now September 2014 and there is still no Official Geospatial Server SS4 released, is it safe to assume that we can download the SS4 components of the Geospatial Server bundle separately and upgrade to SS4, or will there be licensing issues?
    - ProjectWise Integration Server V8i (08.11.11.590)
    - ProjectWise Geospatial Management V8i (08.11.11.35)
    - ProjectWise Connector for Oracle V8i (08.11.11.28)
    - ProjectWise InterPlot Server V8i (08.11.11.56)
    - ProjectWise InterPlot Organizer V8i (08.11.11.56)
    with
    ProjectWise Caching Server V8i (08.11.11.590)
    ProjectWise V8i (SELECTseries 4) Integration Module for AutoCAD 2015 (English) x86  (08.11.11.799)
    ProjectWise V8i (SELECTseries 4) Integration Module for Revit 2015 (English) x86  (08.11.11.789)
    ProjectWise Connector for ArcGIS V8i (English) x86 (08.11.11.27) (Still no SS4 released...)
