Hello
I use Bentley Map (SELECT series 1) and db MS Access (connection successful, column Mslink in my table exists, table Mscatalog is created). I know how add link to another file, but how add link to row in db i don't know.
Object on in my .dgn file must have ID, and using this ID, i must add link to db?
Where i can see it's ID and change him? If it is, say me, please, how this do? Where is it tool menu in Bentley Map?
And another question: objects in my file it is Associative Region. I need change this type on Polygon or another type, to add links to rows in db?
Tamara
Russia
Let me make sure, you have a record in the DB and graphics in a drawing, but they are not linked, is that correct ?
In Russian ( through Google translator)
Позвольте мне убедиться, что у вас есть записи в БД и графика на рисунке, но они не связаны, не так ли?
Thank you, you can write me only in english )
Yes, it is. Database contains data about natural phenomena. Picture - it is boundaries of the regions RF. I want to join natural phenomenas with regions (I hope you understand me, i do not know English very well).
I found in help Bentley Map, what links are created with Database Tool "Attach Active Entity". But, when i use this tool, i see it message: "The element does not satisfy the database criteria"
Element must have a specific format?
There must be a primary key that is unique. Typically this is a numeric, integer.
Good, i suspected. This ID can be added manually? Or it in file ***.dgn automatically assigned, when element created?
You need to add this ID field to the database table. Then perform the linkage via the tools in Bentley Map, as you have discovered.
Thank you very much! You really helped us
We will work in this direction
