I would like to rename all the levels within a file before it is published using the automated idpr converter. First I tried using a Microstation keyin script file without success and then I tried to run a VBA from both the Keyin B: and the Keyin C: parameters (again without success). Can someone tell me how to use the Keyin parameters successfully?
Thanks in advance
Greg Young
Did you found an answer for this?
There are options in the GWP publishing to define 3 different keyins. these keyins can run mdl applications and should run VBA . Of course you need to make sure the environment is set up to find either the MDL or VBA code that you want to run.
