Now layer is published but it doesn't show up in Microstation. Only infamous crossed "old camera picture" is shown which doesn't give any clues what is wrong. Same issue on other test server I tried. Also log files are not of much use because it reports that an XML exception was sent to request but MS doesn't show it anywhere.
A number of things that could possibly help
Does it work if you test it in the server?
Can you display / publish for example the Whistler map example in MicroStation?
Could you test the WMS in MicroStation with iDPR layers (in the server and in the client)
If you open the .xwms is the URL correct?
Carlos
Later when community file attach will be fixed I will put some screenshots.
Other service publishing works only issue with tDPR. Just tested creating new iDRP. Attaching tDPR it creates correct xWMS file but it doesn't work if I zoom to tDPR zoom level as for testing created two layers, one iDPR for overview and other for tDPR, only tDPR gives error.
Hi Oto,
The problem uploading files seems specific to IE, with Google Chrome or Firefox should work.
I will do a test at my end with tDPR in the meantime.
Attaching screenshot and log.
In Map Viewer slowly but it shows correctly at least in some zoom levels but returns white background if zoomed in other areas. Also in map viewer I see some streaks all over the map like some elements are streched.
So the issue seems to be with some wrongly published elements which crashes tDPR publishing. There are some v7 files which could cause this although it worked with iDPR.
