Is there a priority build for the ProjectWise GeoSpatial Explorer that works with ArcGIS 10.2.1 for Desktop? There is a WIKI note that explains a priority build is available for ArcGIS 10.1 but I cannot find anything for ArcGIS 10.2 compatibility. If there is a priority build please send me the link to download.
SR Number : 7000132172
Sean
communities.bentley.com/.../11709.is-arcgis-10-2-supported.aspx
Answer Verified By: CMartins
Ok, I read the support solution but I cannot find all the software under the downloads. Based upon the support solution if I am running PWC 08.11.11.559 I would need ProjectWise Geospatial Management Client 08.11.11.36 and ProjectWise Connector for ArcGIS 08.11.11.27. I cannot find ProjectWise Geospatial Management Client 08.11.11.36 as only ProjectWise Geospatial Management Client 08.11.11.35 is listed under downloads on the main Bentley website.
Please not that I am not running any of the ProjectWise Geospatial Server products and only the ProjectWise Integration Server products.
Please advise.
Correction: I read the solution again. I will need to install PWC 08.11.11.579 and ProjectWise Geospatial Management Client 08.11.11.38 and ProjectWise Connector for ArcGIS 08.11.11.27. I cannot find ProjectWise Geospatial Management Client 08.11.11.38 as only ProjectWise Geospatial Management Client 08.11.11.35 is listed under downloads on the main Bentley website.
Hello Sean,
Yes, to obtain the priority builds one needs to contact technical support - you have already done so via the SR mentioned.
I will follow up with you on this directly. Thanks for your patience.
Answer Verified By: Nelson Hobdell
