PLAXIS 3D Moving Load Function
Hi all,
May I ask a question regarding the theory behind the moving loads function in PLAXIS 3D?
I understand that users can assignment Movement to point loads with a linear, harmonic or table based signal specifying an initial velocity, acceleration, or variation of the velocity through time. But, is there any underlying theory behind this logic?
Thanks!Smile
Parents Reply
  • Dear Chua Shin Ying,
    1) The moving loads allow adding a movement function with a direction to multiple points. Those points will share the same movement function, which can be selected in the GUI. This is demonstrated in the video I recommended to check in my previous answer.
    Note that this is not the same as assigning a multiplier to a single load as in this case there is no movement defined, which is the case for instance when modelling a train passing the tracks.
    2) In PLAXIS, the Newmark’s time integration scheme is used to solve the dynamic equilibrium of the system (i.e. time-dependent movement of a body subjected to dynamic loading).
    For further details, please refer to Chapter 5 of the Scientific manual. Similar to what is considered for static equilibrium, the problem is formulated within the framework of continuum mechanics and solved using Finite Element Method.
