Plaxis 3D Tunnel Designer
Dear Sirs,
I am working on Tunnel and Galleries example whilst using the Tunnel advancement tool.  The tunnel has been excavated but the gallery doesn't seem to be excavated from the tunnel. Can you please advise how can I assign the start of the tunnel or what defines the start of the tunnel?
Many thanks
Parents Reply
  • Dear Roumaissa,
    The specific error you encountered is described in our Reference manual and it indicates a numerical issue encountered during the calculation. First you will need to inspect Output results to try and pinpoint the location of the issue.
     In order to find out what the mechanism for failure is, and so possibly determining the cause, these Output plots should be inspected:
    • deformed mesh
    • total displacements (shaded plot)
    • incremental displacement (shaded plot and/or arrows)
    • total deviatoric strain (shaded plot)
    • incremental shear strains (shaded plot)
    • Plastic Points plot
    • when applicable: excess pore pressure plot
    A combination of these plots will usually give insight into what is happening.
    If you cannot explain the reason for this issue, please submit a service request: https://apps.bentley.com/srmanager/ProductSupport
