Load resistance factor design & ultimate limit state design applications in PLAXIS 3D ???
Dear Arpit,
Currently, the Design Approach facility is not yet implemented in PLAXIS 3D.
For now, the only option is to create copies of the material data sets and update the values according to the design factors you have. The new materials can be directly assigned to the soil volumes.
In the case of load factors, the values of the applied loads should also be adjusted in the specific phases accordingly.
