Since we are trying to automise more and more with Plaxis, we try to implement/use our own input-excel sheets to set up a model within Plaxis. We try to use python scripting for this.
I found out that the python environment with the packages within plaxis is managed by Anaconda. However, we are not able to modify the root environment of Plaxis, which I can understand. I am able to make a copy of this environment and add some extra packages to this environment which are pretty usefull to use within Python, such as Pandas or xlsxwriter.
However, I cannot change the python intrepreter from the root environment to this new environment? How can I do so? Or is there another way to install and use extra python packages within Plaxis?
Thanks for your help in advance.
Thijmen Plomp
Hi Plomp
Not sure if you are still finding the solution for this problem. To me it was not as easy as Stefanos mentioned below but I managed to install pandas in phyton for plaxis.
Below my steps.
1. Go to C:\Program Files\Plaxis. Right click on Anaconda. Properties --> Security. Then change permissions for all users.
2. On Windows Start menu search for PLAXIS Input or Output and run it as Administrator
3. Open the command prompt from Expert > Python > Command prompt
4. conda install Pandas
This will install pandas (and other modules) on phyton for Plaxis.
Hope it helps,
Cheers, Gerado
