I downloaded some tutorial files but they were saved for version 2018. How can I open the files by using version 2020?
Thanks for Posting your query on Bentley Forum! Can you please tell us which Bentley application you are referring to ?
Plaxis 2D CE V20, Tks for helping me.
I have moved your post to the correct forum.
Dear Thoa,
PLAXIS software supports backwards compatibility. Any older project files can be opened with a newer version, here the CONNECT Edition V20.
Therefore, you should have no problem opening the projects in PLAXIS 2D CONNECT Edition V20.
If you encounter any issues, please submit a service request.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
