Hi all,
I'm working in a Plaxis 3D model for an underground excavation. Geometry is quite complex due to geology and excavation phases so intersections generate some little triangles that are giving me problems with mesh generation. I've tried with different options (coarseness) for mesh generator but I haven't succeeded. Model is reporting errors due to small edges as follows:
!!!!> _mesh 0.025 256 True 0.5 0.002 0.5Meshing failed with the following error:Fatal: Could not generate mesh.Warning: 1 EMR warning has been detected.Warning: # 1/1 of small edges: detected size 3.37e-02; this is 1.62e+01 times smaller than minimum targeted element size. Related geometries: Polygon_5_13, Polygon_7_9. Inspect the geometry locally.
!!!!> _mesh 0.025 256 True 0.5 0.002 0.05Meshing failed with the following error:Fatal: Could not generate mesh.Warning: 1 EMR warning has been detected.Warning: # 1/1 of small edges: detected size 3.37e-02; this is 1.62e+01 times smaller than minimum targeted element size. Related geometries: Polygon_5_13, Polygon_7_9. Inspect the geometry locally.
Can anyone give some advice to solve this kind of issues?
Thanks in advance,
Francesc
The problem seems coming from this small triangle....
Dear Francesc,
The information you get at the command line is useful to identify the areas where low-quality elements are generated.
Note that good elements are these with the same size for length, height and width of the element. With low-quality elements, issues can be encountered during meshing and calculations.
You are advised to improve/adjust the geometry at those areas to prevent slender (or pie-shaped) elements from being generated.
The screenshot you provided shows a sharp edged object which will generate a low-quality element. In some cases, local refinements can be applied or adjustments need to be made to prevent such geometries.
If you still have problems, please submit a service request.
Then, one of our support engineers can help you faster and in detail: https://apps.bentley.com/srmanager/ProductSupport
Thanks Stefanos. Finally I found a way to solve this issues.
Can you share how you have solved this?
Dear Francesc,I fully subscribe to Asif Mostafa's question.It is very interesting to know what can help to solve such mesh issue.Thank you in advance.
