What is the difference between PLAXIS coupling tool and PLAXIS structure interaction (PSI) tool ?
Dear Hossam,
With the release of PLAXIS 3D CONNECT Edition V20 we created a structural coupling with STAAD.Pro. This is available under Expert menu as this is a tool implemented by us.
Note that the PLAXIS structure interaction (PSI) tool is a tool implemented by a third-party. You can find more information on the page below (may need translation):https://www.plaxis.ru/plaxis-structure-interaction/
Answer Verified By: Hossam Adel
You may be interested in the upcoming live session titled:From Structural to Geotechnical. Deep Foundations Analysis in PLAXIS 3D from a STAAD.Pro Model
Click here to Register now.
Dear Stefanos,
Thanks for your reply. So, PLAXIS structure interaction (PSI) can be used only with permission from the third party or it is considered as a PLAXIS VIP tool ?
According to the webpage, the tool can be used for free. As a prerequisite is, indeed, to have the Geotechnical Select Entitlements (formerly known as VIP license).
I would advise you to contact the third-party for more information.
PSI can be used by any company that has PLAXIS 3D SELECT (VIP). If you have any questions about PSI, please send it to psi@nipinfor.ru.Thank you.
