i want to write a python script for soil test for remote scripting in Plaxis.
Could anyone help me with minimum working program?
Dear Lupamudra,
It is not clear at which step you encountered issues.
With PLAXIS CONNECT Edition SoilTest it is possible to use the Python scripting facilities as SoilTest has a command line. To begin with, you can use the Command reference that is provided.
In order to assist you at the exact step you have an issue, please submit a service request.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
hello!
I am stuck in this problem,too.Did you have your problems solved? Can you share some solutions if possible?
thanks!
Hello Jianshu,
You will need to elaborate more on what the problem is so that we can help you.
Solution and lots of articles can be found here: https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45393/api-python-scripting---plaxis
Thanks for replying
I have problems in the output of the results of the soil tests, I can do "calculate triaxial" in python code, but i can't find the command or python code corresponding to the output of the results. I can double-click the curves and copy the results to clipboard and my question is how to realize this step by command or python.
thanks,sincerely
I have just answered to this in the other post you made:communities.bentley.com/.../how-to-do-soil-test-in-python
