Output results when using mm units
Hello everybody,
I am trying to reproduce oedometer and triaxial test with Plaxis 2D, and when I select mm units, the strains results are not accurate; for instance, a 25 mm tall specimen subjected to loads up to 800 kPa shows a maximum vertical strain of 6,4*10^-7. Also, the stress shown on "curves tool" are inexplicably high, i.e ( 118096 kPa).
This situation does not happen when I model with a metric sample i.e (1x1 m), then, results are "normal".
Could somebody help me please?
Parents Reply Children
