Hello everybody,
I am trying to reproduce oedometer and triaxial test with Plaxis 2D, and when I select mm units, the strains results are not accurate; for instance, a 25 mm tall specimen subjected to loads up to 800 kPa shows a maximum vertical strain of 6,4*10^-7. Also, the stress shown on "curves tool" are inexplicably high, i.e ( 118096 kPa).
This situation does not happen when I model with a metric sample i.e (1x1 m), then, results are "normal".
Could somebody help me please?
Dear Daniel,
You should be able to access the Service Request Manager now.
The issue was the fact that your account was not affiliated (linked) to the Univesity account. Typically this is handled by your local (site) administrator, IT manager, as explained in step 6 in my previous message.
I will create your first service request and send you some extra information about your account.
