Dummy plate properties in PLAXIS 3D.
Dear all,
When modelling a pile with a section of 100cm by 320cm using a volume element in plaxis 3D, one is required to introduce a dummy plate such that the plate will not affect the results.
My question is if my real E is 32 GPa and I know that the unit weight must be set to zero, what will be the value of E1 (assuming that E1=E2) and d (thickness)?
In the output, what value do we multiply with the forces to get an actual value of N,M and V.
Thanks.
