Greetings,
I need to model slope with unhorizontal soil layers.
We have recently purchased Plaxis 2d Connect and we always have the same problem. The problem is that initital phase (gravity loading) stops already after few seconds. The message is that soil body collapses (error 101) even after increase of parameters. We have checked model fixities and everything is ok.
In the output program soil collapses unlogically in the upper right corner of the model.
We used older Plaxis versions and we never had such strange and unrealistic failures after only 3 seconds of initial phase calculation.Please help, the image of soil colapse is attached. Why is this happening? Oldeversions we had never had such issues.
Hi Rayyan,
Submerged unit weight of soil is defined as the difference between its saturated unit weight and the unit weight of water.
Submerged unit weight = Saturated unit weight - Unit weight of water
thanks for the explanation
Saya sudah mencoba cek geometri, dan tidak ada masalah, apakah ada solusi lain? Tolong
parameter kekuatannya terlalu kecil kayaknya
