Hello again,
In my geotechnical application, the vertical load is critical comparing with the horizontal or the moment... So, in this case, is the Eur from the oedometer can do the job?
On the other hand, I also have a question please about the reference pressure in the HSM, if I don't have the same reference pressure in the triaxial and the oedometer what shoul I do? Can I correlate the Eoed depending on the reference pressure of the Triaxial test? (By assuming that the Eoed is linear compared to the reference?)
Thank you in advance.
Dear Adnan,
It is possible to use the unloading/reloading stiffness from the oedometer test instead. We know that based on Hooke's law you can correlate the Eur,oed to the Eur,triax and for a low Poisson's ratio (vur) these are Eur,oed ~ 1.1 * Eur,triaxIn any case, you will probably need to do a calibration with SoilTest for the Eoed,ref, therefore, you can also directly use the Eur,oed and see if that matches the laboratory data you have.
Regarding the different reference pressure, you can use the equations in our Material Models manual that define the E50, Eur and Eoed based on the reference pressure you have (σ'3 for triaxial test or σ'1 for oedometer test) and the power m parameter. In our latest manuals, i.e. CONNECT Edition V20 Update 2, these are equations 6.3, 6.5 and 6.16, respectively
Typically for sand m=0.5, so, for example, you can calculate E50,ref = E50 * sqrt(pref/σ'3) in which pref = 100kPa and σ'3 is the reference pressure you have.
Dear Stefanos,
Thank you very much for your detailed response, it is so helpful.
In this context, I just have a small question, why always on Plaxis we take the Poisson's ratio "0.2" for the soil? (I guess that's why we have 1.1 between Eur and Etriax).
Thank you in advance,
Adnan.
Hi Adnan
A Poisson's ratio of 0.2 is a typical pure elastic unloading/reloading Poisson's ratio. This works well for e.g. the Hardening Soil model as a default value. In Mohr-Coulomb model it cannot just be this unloading/reloading Poisson's ratio, as the Mohr-Coulomb model just has one stiffness. Typical ranges is 0.3-0.35. To be sure, please run a SoilTest simulation to see if this is a valid assumption.
