for the output of a plate element unit, I understand in Plaxis 2D, output unit is kN*m/m, that is in/out of plane issue.
In plaxis 3D, i have a piled protection slab for gas main, the output unit of plate element is still kN*m/m, how do I interpret the total moment, just ignore the /m ?
M11 and M22 is in 2 different directions of local axis, the plate is very long along the gas main and I don't believe I need to times the length of plate to represent the total moment kN*m. So why the output is shown as kN*m/m
Thank you - that is a huge help! And the units are still lbf ft/ft. Is that per foot in the direction perpendicular to the cross section or do I need to calculate the area under the curve drawn (like i've shown with the blue trapeziod in very poor freeform drawing).
Hi Sonia,
This is per foot perpendicular to the cross section. it's a distributed bending moment per meter width....
With kind regards,
Dennis Waterman
Sir Stefanos, what do you mean when you mentioned "integrate the bending moment over its length"? Can you please show the mathematical interpretation for this? Thanks!
I am using Plaxis 3D, and I actually have a similar problem but the difference is my model is a circular tunnel plate (dia=0.10m) and the length is less than 1 meter (0.06m.)..
Dear Mikael,
Thank you for the screenshot as it helps understand what you have to deal with.
So, in this case, you have a surface plate element with a width of 0.06m and you want to know what is the bending moment at specific locations. The bending moment presented in PLAXIS Output has units of kNm/m because these are the proper units for a surface element, based on the assumptions mentioned before in this post.
If you want to assume that this tunnel slice, i.e. 0.06m, is a line element you would integrate the bending moments you see, for instance, when hovering with your mouse using the Hint box (or in a cross-section), over that perpendicular direction.
Assuming that the bending moment is constant over the perpendicular direction, you would multiply the value you see with 0.06m in your case, giving units kNm. That would give you an equivalent (assuming constant) bending moment over a 0.06m slice.
