Calculation failed, will soil body inside excavation zone "collapse"?
Dear All,
The calculation failed for my excavation stage, after inspecting the fail result, I cannot find any soil body to be collapse...
Will soil body inside excavation zone "collapse"? because of the total displacement in arrow as this...
Thank you.
William
Parents Reply
  • Hello William,
    Great catch. Indeed, most of the times the boundary and soil conditions are to be blamed for incorrect results.
    A tip is to always check the Preview of the phase before calculation to ensure that the steady-state pore water pressures are defined properly. This is a quick first step.
    Of course with a groundwater flow analysis, the model behaviour can be affected by the water flow, which is a result you can only see during or after the analysis.
    Answer Verified By: William Lau
