Expert Command - Improve Command Loading Speed
Dear Sir/Mdm,
I am currently running many commands through a p3d.log script using the command runner window in PLAXIS 3D. However, as I am running over 10 000 command lines, the time required for the file to finish running is quite long. May I know if there is any way for me to speed up the process? Thank you very much!
Parents Reply Children
