Creep calculation in SSC model
Hi everyone,
I have a question about the creep formulation in the Soft Soil Creep model.
The SSC model starts from the assumption that all the inelastic strain are creep strain and depends on the load application time.
The volumetric strain rate, expressed as in the in the formula 10.23 (material models manual), are inversely proportional to tau.
In the manual it is stated how this formulation is based on 24 hours oedometer tests.
What if the determination of the modified secondary compression index took longer testing period rather than 1 day oedometer step?
Is tau equal to 1 day in any model simulation, or it turns into the length of my consolidation period?
Thanks.
